Paint guns
Nathan in OK
09-03-2004 10:41:22
Hello,
me again, what kind paint gun is better the ones that gravity feed or the internal mix ones?
Thanks Nathan
curt powell
09-04-2004 20:08:00
 Re: Paint guns in reply to Nathan in OK, 09-03-2004 10:41:22
Hi i have been painting for about ten years now and have just bought a new gravity feed gun,It is the devilbiss finishline 3.I am really pleased with its performance for the money i dont think you can wrong with that setup, my opinion Curt
Nathan in OK
09-04-2004 11:59:59
 Thanks in reply to Nathan in OK, 09-03-2004 10:41:22
Thanks for all the input guys. I think i'm going to get a gravity HVLP gun.
Thanks again, Nathan
Nathan in OK
09-04-2004 11:58:00
Seth
09-03-2004 20:07:49
If you are choosing a gun I still think non-HVLP type guns are the way to go. HVLP type guns are supposed to have less over spray and use less material. This is all well and good but they do have there draw backs that I do not like. From what I have seen and heard you can paint faster with a non-HVLP type gun. Every one that I have seen use an HVLP guns moves to slow for my like. Also hvlp guns take a lot of air. You need a very good(expensive)compressor. I use a binks model 7 gun with a one quart siphon pot. Have had the gun for probelly 30 years and love it. I think I would buy another if ever needed. I recently saw some place on the internet that sold them for $270, but list was supposed to be $350. Well worth the money in my opinion.
Rod (NH)
09-04-2004 08:06:08
 Re: Paint guns in reply to Seth, 09-03-2004 20:07:49
Hi Seth,
That Binks #7 is a classic, similar to my 30 year old DeVilbiss JGA. They are both still available too, if one is not limited by some legal requirement for HVLP. Yes, they have more overspray and therefore more waste. That may or may not be important, depending on quantity and cost of materials used. I have an HVLP spot gun and when using that, I have to get closer to the surface and my travel speed has to be less than what I am used to with my non-HVLP spot gun; feels like I am painting in slow motion. It's easier to clean though, I'll give it that. HVLP is the "standard" now and will be into the future. Like you however, I am one of the dinosaurs and will continue to rely on my trusty JGA as long as it continues to do the job as well as it always has. It's also more flexible than current HVLP models. With the different fluid tips and air caps available (or were), you can get a good 16" fan pattern if you have enough air supply to support it. I once painted a VW bug with such a large pattern. Pressure feed with a 16" fan -- real impressive to watch the paint go on that fast on a small car :o).
third party image Rod
Dozerboss
09-03-2004 21:17:37
On a light note i had a binks model seven starting out. Apparently the fact i didn't buy from the local paint supplier irked him. He called it a house paint gun. All he had was the import stuff.
The main problem i had with the binks was clogging at the vent tube at the top of the cup. You really needed to watch the little hose while painting, or it would quickly start to clog and you would have dry spray. It did spray good when the tube stayed clear. It ruined the one job i wanted to do perfectly, my Dads truck. He never had the patience for proper paint prep, when i told him we needed to let it dry and resand the dry spray--he didn't want to hear that, "good enough just go over it again".
After the Binks i went to a turbine system and found it limited my movement too much, and you can't get low with the bigger hose in the way.
I like the lower overspray with the gravity feed hvlp guns. One feature i don't like is filling the cup and how easy they tip over on you due to the extra length with an air gauge. I spray outside a lot and don't have a screwed down cup holder stand a lot of times. The phone will ring and the slightest touch of the hose will bring down the house. That was the hardest thing to adjust to for me. I need to mount a holder stand on a 12 x 12 and disconnect my hoses i guess. I don't have a problem with the hvlp speed except with the touch up gun. It works best for me so far with 20 cfm to work with. I use 1/2 inch hose fed by 3/4 pipe from the compessor with a 3/8 swivel whip hose with the hvlp connectors for the gun. Also the highest flowing connectors on the 1/2 hose--military type P. Helps the flow quite a bit, you need a strong hand to uncouple them at full pressure. Not as much as i would like for blasting but enough for everything else.
I haven't tried the pressure feed yet and being able to paint in odd angles sounds appealing. Rod what kind of pressure feed gun are you using?
Rod (NH)
09-04-2004 08:09:34
 Re: Paint guns in reply to Dozerboss, 09-03-2004 21:17:37
DB,
I agree, trying to set a gravity feed gun down temporarily is a real PITA. I made a portable free standing custom support cradle for my HVLP spot gun:
third party image
My full sized gun is an old Devilbiss JGA used in pressure feed mode with a two quart remote cup. True all position painting with no weight of paint in your gun hand. A real blast to use for any project requiring a full sized gun -- the only way to fly IMO. And you don't have to worry about any clogs or drips from the cup. Try it, you'll love it. Downside? You'll always have the quantity of paint in the fluid hose left over, as a minimum, and it is harder to clean because of that additional hose (about 3 feet typically). Here's my JGA setup:
third party image
PG1 is air pressure "at the gun" - adjusted by remote, wall mounted regulator
PG2 is pot (paint) pressure
REG1 is pot (paint) pressure regulator
Most of the name brand suction feed guns are readily convertible to pressure feed / remote cup by changing the fluid tip and needle assembly and removing the suction cup. You might also have to change the air cap. Typically a standard suction feed 0.070" (1.8mm) tip would be replaced by a 0.042" (1.1mm) tip for pressure feed. The same tip can be used for all automotive paints. For surfacers, just up the pot pressure (normally 10-15 psig) a little. If you wanted to just try out the concept without spending a lot of money, Northern Tool has a complete "knock-off" arrangement for $80. No guarantees on quality though :o).
Big Jim
09-08-2004 00:04:53
 Re: Paint guns in reply to Rod (NH), 09-04-2004 08:09:34
There are pressure pot fed HVLP guns available. I bought a Sharpe setup used a couple of months ago but haven't had a good use for it yet. I thought it would be a Win-Win. HVLP transfer efficency and a gun you can thread in a big hole upside down. I broke out an older detail gun the other day for a small job and I was amazed at how much overspray there was in the air since I've gotten used to HVLP. If you are using $300 a gallon or up automotive paint, the material costs could be a lot different.
Dozerboss
09-07-2004 20:50:23
Rod,
Thanks for all the details and photos. There is a northern tool about 50 miles away. Next time i go to the big city ,I will have a look.
Rod (NH)
09-03-2004 15:21:52
Hi Nathan,
There are three basic types of feed for automotive type spray guns:
1. Suction feed
2. Pressure feed
3. Gravity feed
The gravity feed guns are currently the most popular style, usually in a HVLP configuration. This style has the paint cup on top of the gun. Suction feed was the most popular years ago. It has the paint cup hung under the gun and is now usually a non-HVLP type. Pressure feed is not that common for automotive work but I prefer it although it is harder to clean than gravity. Pressure feed is available with attached cup hung under the gun (like suction feed) or in a remote cup configuration which I think is best. Pressure feed can be either HVLP or non-HVLP and is typically for larger jobs than cars. The common remote cups hold 2 qts so you can cover larger areas before having to fill up -- plus there is no paint weight in your gun hand and painting upside down and at odd angles is easy.
There are two types of mix: 1) external where the atomization air is mixed with the paint after the paint leaves the tip and 2) internal where they are mixed behind the air cap. The internal mix requires a special air cap -- forget it for nice work. I don't think it is ever used in automotive work. Might be OK for house paint but I wouldn't think of using it for anything.
As far as the type of feed goes, which one is "better" is more a matter of personal preference. The external mix air cap is, in fact, "better" IMO.
