painting shop roof.
Hilltopper
09-06-2004 14:51:57
My shop roof is galvinized metal. It is 19 years old and is beginning to show a lot of rust. I have not found the work of barn painters to be much help, that is spraying aluminum asphalt. I was thinking of trying to sand or wire brush the bad spots with an angle grinder and then prime it before using latex paint. What type of wash should I use before the primer is applied and what should I use as a primer. A person at Home Depot recommended KIlZ 2. I would appreciate comments. Thanks.
Big Jim
09-07-2004 23:49:59
 Re: painting shop roof. in reply to Hilltopper, 09-06-2004 14:51:57
I'd suggest you look at KoolSeal. It goes on like a thick latex, cleans up with water, is available in white or aluminum (possibly black). You'd want to brush off any rust and use their patching material on any bad spots. The can has specific cleaning recommendations. I think it would hold up a lot better than paint. I'm doing a motor home roof with it. The white is REALLY white and reflects a lot of heat.
