High Temperture Paint for Manifolds on Tractors
Bill from Senec
09-08-2004 18:39:40
Hi, Can anyone tell me if there is a high temperture paint. That will work on a manifold everything that I have used will not work. Thanks Bill
Kendall
09-17-2004 09:05:32
 Re: High Temperture Paint for Manifolds on Tractor in reply to Bill from Seneca,IL, 09-08-2004 18:39:40
I cant remember the brand I used but it required baking in the oven after it dried. It had a powdery feel and could have been rubbed off somewhat before I baked it. Its been holding up real good. I guess the moral of the story is to read the can and if it says to bake the manifold before use, then its a good one. I could have let the engine bake it from exhaust heat, but It would have been messed up from handeling by the time I got everything put back together.
chvet73
09-08-2004 19:39:44
I have used Eastwood's manifold paint in grey color with good success.
Butch(OH)
09-11-2004 06:28:25
 Re: High Temperture Paint for Manifolds on Tractor in reply to chvet73, 09-08-2004 19:39:44
My experience with Eastwood's manifold paint is it does OK for idling on and off a trailer but will not last long under the heat of a little work, same as the short list of other manifold paints I tried. Somewhere I read that Eastwood's paint has been improved recently, my experience was 5 years ago. I think Dozer is right in that no paint is going to stay on a cherry red manifold but the best I have found is the grill paint which is also sold as stove black. Outside of cherry red it will stay on and stay black.
Dozerboss
09-10-2004 23:22:30
Ditto, Eastwood has held up on blasted manifolds on cars for me. All their specialty paints are expensive. Wonder if tractors have higher temps?
Butch(OH)
09-08-2004 18:47:15
I tried several of the special manifold paints with the same reults you have. I now use barbeque grill paint. It doesnt last forever but much longer than the others and is cheap to boot.
