How many coats of 170 primer?
Paul_NJ
09-10-2004 17:42:57
I took the advice of Rod(NH) and others on this forum and tried Omni 170 today on the rear rims of my Cub. I had the rims sandblasted earlier today. I was really impressed - great coverage and a really smooth hard coat. Flowed well, looks great. Couldn't make it run. You were right again!
I know there's a recoat window (for the MTK topcoat) of about 3 days. How many primer coats would your recommend, however? I shot the 170, let it dry for a few minutes, and then added another coat. After allowing 30 minutes to dry, I flipped the rims and shot the other side. Is that sufficient coverage durability wise? Looks great to me.
By the way, I used a green 3M masking tape on the rubber, and it stuck fine. I know this has been a topic of considerable discussion.
Once again the recommendations I've learned from this forum has been invaluable.
Thanks
Paul
Rod (NH)
09-10-2004 20:17:01
 Re: How many coats of 170 primer? in reply to Paul_NJ, 09-10-2004 17:42:57
Paul,
That should do just fine. The tech sheet for 170 says one coat but I always use two. That thinking goes back to when I was using PPG's premier epoxy primer, DP (DPLF nowadays). That product calls for 1-2 coats -- two coats specifically if a chemical pretreatment or wash (etch) primer is not used. I use epoxy direct to sandblasted metal w/o any pretreatment so I got used to using two coats and it carried over to my use of the 170. I think two coats is a good idea in this instance since the 170 tech sheet is not as specific as the one for the DP.
CNKS
09-10-2004 19:18:09
P-sheet says one, I use two because I can't paint good enough to cover everything with one -- You should be ok.
Dozerboss
09-10-2004 23:11:14
 Re: How many coats of 170 primer? in reply to CNKS, 09-10-2004 19:18:09
They do specify one and if you miss your window it says scuff/sand and reapply. So nothing wrong with 2. I questioned the one coat in my mind the first time I used it, until i saw how it sprayed and covered.
