Pitting?
mike m
10-12-2001 08:01:13
I have pitting under the battery area on a farmall B. What can be done?
Bill
10-13-2001 07:03:34
 Re: pitting? in reply to mike m, 10-12-2001 08:01:13
If the pitting was done by battery acid you will have to clean the pits out as good as you can and neutralize the acid with Baking Soda and wash with cold water. Then you can tin the area--I use self tinning flux and a propane torch, you can then fill the pits with solder,smooth it off and repaint.I have used lead to fill pits but it is dangerous to your health--lead free solder is easy to get and safer.
