Engine paint advice
Rory A
09-28-2004 11:30:42
I am in the long process of restoring a 47 dodge pickup, and in the process I sand blasted the engine and then primed it (after reassembily). My problem is that this was a couple of years ago and now it is starting to rust again, and I dont want to sandblast it again. Is there a good way to remove the rust without contaminating the engine, and what kind of paint would you recomend to use so the rust wont come back?
Frank Stalfire
09-28-2004 11:43:27
 Re: Engine paint advice in reply to Rory A, 09-28-2004 11:30:42
HI Rory
As for the rust, if it's light and not pitted a red scotch brite wet with solvent, mineral spirits, laquer thinner ect., or a wire wheel should clean the surface adaquitly. and for paint , definatly an epoxy primer followed by a urethane topcoat. Dupont Centari is good up to 350 degrees and Dupont industrial coating Imron 3.5HG will go to 450.
