Frank Stalfire
10-02-2004 19:40:02
Re: ? for Frank Stalfire in reply to Rod (NH), 10-02-2004 10:34:28
Hi Rod Thanks for the welcomeing words, I recently bought a farmall B and was wondering about a grill when I found this forum, I enjoy being able to help when I can and I realize the audience may not always be the professional painter and I am adapting to that and trying not to be to technical with responses when I can. As far as 1K enamels, you have to understand ALL the paint companies focus soley on the collision refinish market, thats were the money is, about 1 billion a year. So there is little money put into the older technologies like enamel. Yes the solvents have changed and we are actually changing a majority of them again right now, we are no longer able to get a raw material resulting in redoing an entire platform of reducers and catalyists. The lifting you mention on recoat was when the finish was in the "gel" phase, you could get on it before or after but not during. A solvent change has changed things, thank fully. As for confirming that recoatability in Centari and Nason is safe, My understanding is that isssue has been resolved and the products are recoatable in the window provided in the tech sheet, I have not personally tested these 2 products. As for other offeringss to guys with working tractors, I really beleive the Dupont Industrial line has a Copolymer water borne line that would be a GREAT fit, it is Non iso, water reducable, low VOC, can be brush, rolled or sprayed, and is hands down more durable and will have alonger life cycle than any auto finish. The problem, VERY thick and requires a pressure pot or pressurized cup gun to apply by spray, is not an auto motive type gloss, is not available in all colors, can be custom mixed if you provide a sample of the color you want, I think the farmer wanting to paint his tractor would have better luck and have a better finish with industrial than a low end auto finish. I know you guys have had no exoposure to industrial, it was only available to the factories up until 4 years ago, but it would be something to check out.
