Total novice with some paint questions.
Super 55
10-04-2004 22:15:27
Funny thing I don't think I even noticed this part of YTMag before, but I have some painting questions. I am toatally a novice at painting if you don't count spray cans.
I am painting small parts off my tractor as I find time to fix them. Right now I am working on the transmission cover of my Super 55 and all that goes along with that. I noticed there was a posting for what type of gun to buy. I bought a low end HVLP because I heard they were the way to go, but I don't think my small compressor can handle the volume so I bought a regular siphon gun....it was cheap. I am to embarassed to tell you how cheap it was, but you know what? I used it to spary primer on the weekend and I think (remember no experience) it did a really good job. No runs, no drips nor errors and covered well. I was using a PPG epoxy primer. One of the restoration books said that epoxy was a good filler and etcher in one.
I also bought some AGCO Oliver Meadow Green paint. I was told by the dealer that he doesn't put hardener in it when he uses it, but a lot of fellows I talk to say I should. The question is, what type of hardener? All the paint can says is machineray enamal, and it contains xylol and tuluol.
Now, I want to ask some questions about the spray gun. It was cheap, and it seemed to do a good job. I know you usually get what you pay for, but what makes the more well known guns so much better? Is it better pattern control? Right now I am just using it to do my tractor. It puts down an even coat and I even thought it "sounded" good when it sprayed. It was easy to clean up with gun wash too.
When I get to the sheet metal it might be a different story.
Frank Stalfire
10-05-2004 19:40:02
 Re: Total novice with some paint questions. in reply to Super 55, 10-04-2004 22:15:27
As a novice and someone who doen't plan to paint often go ahead and stick to a cheaper gun, the high end stuff is better quality in regaurds to precision machining, finish, longevity of gun fit finish, and when you have a problem you will have a tech line to call and you can buy replacment parts, but if you wont be painting often lower end guns are fine. Epoxy is by design, a non-sanding 1-2 coat product that serves as a direct to metal primer that can be directly topcoated if desired. Mostly directed at the fleet and equipment markets where a 2 step process is desirable and no surface sanding is required, as CNKS said if you want sheet metal to look nice and need to sand apply a primer sufacer over the epoxy.
Super 55
10-06-2004 07:39:58
 Re: Total novice with some paint questions. in reply to Frank Stalfire, 10-05-2004 19:40:02
Thanks for the reply. I was getting info from "How to Restore Tractors" by Tharran E. Gaines. "Epoxy is the easiest to use because it combines the qulaities of a metal etch, a primer-
surfacer, and a primer-sealer all in one..... .Epoxy primers can be used in one of two ways. It can be used a primer-sealer, where you sparay it on, wait 15-20 minutes, and start top coating with your color. Or, it can be used a a prmer-surfacer to cover minor flaws in the surface. In this case, you will want to put down two to three coats, giving it 15-20 minutes between coats. Then, wait at least six hours before sanding the surface."
My instruction sheet says I have up to 7 days to topcoat. The parts I am painting are small parts, many of them cast and are not going to require any sanding. The only sanding I need to do, according to the fact material fact sheet, is if I wait more than 7 days I have to sand with 400 girt sandpaper.
When it comes to the sheet metal I will take your advice and use a primer surfacer. That may be next summer.
Rod (NH)
10-05-2004 17:43:42
Hi,
Butch gives you some good advice.
Why do you think your compressor cannot handle your HVLP gun? The conventional wisdom typically applied to auto painting doesn't always apply to tractor painting. You do not necessarily have to have the compressor cfm equal or greater than the gun cfm. This is especially true if you are painting individual parts separately. I suggest before you give up on your HVLP gun, do the following "dry run" without paint in the gun:
1. Install a pressure gage at the actual inlet to your gun.
2. Using whatever regulator you have (wall or compressor-mounted), set the pressure on your gun gage to the proper pressure as indicated on your gun handle or in the documentation that came with it. For an HVLP gun, this will typically be something like "29 psig max". You do this with the air fan control knob wide open and with the gun trigger pulled.
3. Pick the largest individual piece that you plan on painting - e.g. the hood.
4. Start with a full storage tank after the compressor has just shut off.
5. Go over your part just as you would if you were actually painting it. Make sure you overlap your passes at least 50%. 6. Monitor your gun pressure gage throughout this "dry run".
7. If, when you are done "painting" the part, the pressure still equals what you originally set it at, you are good to go with the real thing.
If you can complete a single coat on the largest part and still maintain adequate pressure at the gun, you should not have a problem, even if your compressor capacity is quite a bit less than your gun requirements. The wait time between coats (typically 15 or 20 min) will permit your compressor to catch up.
You might also want to consider a "spot gun" (also called a jam gun or mini gun). They use a lot less air than a full size gun and are very satisfactory for many tractor parts. I even painted the hood successfully on my AC-B with a just spot gun. In fact I prefer it for just about anything not more than a few square feet per coat.
My strongest recommendation though has to do with breathing safety. If you are contemplating using a hardener because someone recommends it, please consider the potential health hazards of doing so without using a positive pressure, fresh air-supplied respirator. There has been a lot of discussion of such safety aspects on this forum. Do a search on the words "isos" or "isocyanates" for a lot of background reading on the subject.
As long as you don't expect a champagne product the first time out on a beer budget, you'll do just fine. You may also want to do a little practice painting on a large vertical piece of scrap sheet metal before topcoating your actual parts. It's well worth the extra time spent, IMO.
The PPG epoxy primer is a great product by the way. I would take issue with the characterization "good filler and etcher" though. Neither the PPG DPLF or the OMNI MP170 epoxy primers have any significant fill capabilities. They are non-sanding primers that are for priming bare steel, not filling scratches. They also do not have any chemical etch properties, at least not in the conventional sense that an "etch primer" (a quite different product) does. Other epoxies may but the two PPG ones do not.
third party image Rod
Super 55
10-06-2004 07:50:03
 Re: Total novice with some paint questions. in reply to Rod (NH), 10-05-2004 17:43:42
Thanks for the info. I printed out your test information and will try it out. One thing that kept me from using the gun, was the instruction manual was just about useless for a first timer. It doesn't even identify all the parts of the gun. It is a small HVLP.
CNKS
10-05-2004 17:28:07
I agree with what Butch said. As to --- "epoxy was a good filler and etcher in one". NO. Epoxy does not fill at all and is non-sandable. Epoxy does not etch, etch primer does. The problem is that both are sometimes called "e-prime". On the sheet metal you need a surfacer on top of the epoxy, or etch primer, whichever you used, so you can sand it smooth before topcoating.
Super 55
10-06-2004 07:53:14
 Re: Total novice with some paint questions. in reply to CNKS, 10-05-2004 17:28:07
Thanks for the info. I took all the parts to bare metal they were sand blasted. Many are cast.
This is the reply I put to a post above:
Butch(OH)
10-05-2004 04:52:22
As always, my advise is that the hobbiest should not play paint chemist. Some get away with it and some get to remove a mess and start over. If there is not a hardener listed on the can or spec sheets I would call the manufacturer. I have heard differing reports on the quality of AGCO paint but the price scared me away. A person can go with PPG or Dupont's low end urethanes or enamals for less money. The reason some paint guns cost much more is threefold. The machinework required in the air cap is complicated, more precise = better finish and more money to produce. The high end guns are made of better materials. And lastly a person pays for the name on a few brands. If you are satisfied with your results then you should be satusfied with your gun however laying primer down decently and achieving a fine finish with your top coats are not the same animal. A person can spend less than $200 and have a gun that will do a very decent job and last long enough to be a lifetime gun for most hobby painters. Mine is an Astro but there are several others.
Super 55
10-06-2004 08:01:03
 Re: Total novice with some paint questions. in reply to Butch(OH), 10-05-2004 04:52:22
Yep, I don't plan on putting hardener in unless I hear from someone EXACTLY what I should use. I tried emailing AGCO, but they don't have an info line, so I emailed O'Brien Co. who are an AGCO dealer, they didn't have the information. It looks like I won't be putting a hardener into it. What are the benefits of the hardener over not using it. Does it actually give a harder finish, or does it shorten the curing time? If enamel paint doesn't have the hardener in it wil it dry to a hard enough finish to be practical?
Frank Stalfire
10-06-2004 19:25:22
 Re: Total novice with some paint questions. in reply to Super 55, 10-06-2004 08:01:03
The problems you are running into are exactlly why when buy a known brand you get more than a can of paint, you have a contact number if you have questions. Adding hardener changes the chemistry of the paint, with out hardener the paint dries by solivent evaporation and is reversible by heat and or solovent, it never really gets hard just drys. when you have paint with a hardener the hardener acts like the wire in a MIG welder it links the moleculs of paint together and makes the film continus which results in a harder film.
Super 55
10-06-2004 22:15:08
 Re: Total novice with some paint questions. in reply to Frank Stalfire, 10-06-2004 19:25:22
Thanks for the info. A post on the Oliver page actually has the correct hardener to use.
here is his post:
I have used Valspar hardener in AGCO Meadow Green paint with good results. You can get it at Tractor Supply for about $9.
I add the hardener, stir occaisonally for 15 to 30 minutes to let the paint and hardener blend, then reduce it with DuPont 3812S (fast) reducer, add a few drops of Smoothie fisheye eliminator per quart and shoot.
On a hot day, I will use a 50/50 blend of DuPont 3812S (fast) and DuPont 3864 (slow) reducer to improve gloss and flow.
It isn't Imron, but the AGCO paint goes on pretty well and looks good when it dries.
Rod (NH)
10-07-2004 15:39:57
 Re: Total novice with some paint questions. in reply to Super 55, 10-06-2004 22:15:08
Quite a witch's brew you got there with the four different manufacturer's products in one mix. You should get the correct quantities of each ingredient to use from the same poster since he has apparently already done the crap shoot. Good luck with it. I hope it works out for you. Most would not recommend it however.
CNKS
10-06-2004 17:43:48
Hardener makes the paint cure faster, and gives added gloss. I doubt if there is much difference in durability between enamel with hardener, and FULLY cured (several months) enamel without hardener. Both will scratch or chip fairly easily.
jpuleo
10-05-2004 21:49:11
I have a cheepo HVLP gravity gun. I painted a Harley using House of kolor paints with clear coat. I can tell you the gun performed superb. Everything came out like glass. Parked next to another bike with a 3k paint job, finish quality was as good, and that was without any buffing. The products were very high quality and that goes a long way, but the gun did as well as any gun could have done.
