Epoxy Primer
burlives
10-13-2004 19:24:38
Had a friend tell me of someone he knew who primed a bus with epoxy primer only to have the primer dry so fast that the surface was covered with chunks of pigment.Left a rough surface.What went wrong? Wrong gun or what?Thanks,I don't wwnt that to happen to me.
Frank Stalfire
10-14-2004 19:57:18
 Re: Epoxy Primer in reply to burlives, 10-13-2004 19:24:38
Hi
Do you know what brand it was? I am a rep for Dupont and we had a line of epoxy's that had a stability problem and left a gritty look to the surface, the line has been replaced but it sounds like the old line we used to have.
Big Jim
10-13-2004 20:25:40
Bad gun
Bad paint
Wrong mix of hardner
Wrong thinner for the temprature
Bad environment - like outside in the sun
A bus - may have taken so long, it went past the pot life of the mixed paint
Possibly bad spray technique.
Best way to avoid problems - read the 'p' sheet for the primer and follow it's instructions to the letter. The manufacturer does know best how to use it's products.
