Primer after sand blast
pat s
10-16-2004 19:21:54
I bought a new hood for my tractor and installed it, primed it with a spray can some time ago, so I could use the tractor. what do I need to do about preparing it to paint now? should I go back to bare metal than use Epoxy or what?
CNKS
10-17-2004 09:51:28
 Re: Primer after sand blast in reply to pat s, 10-16-2004 19:21:54
There is more than one answer. I would strip it, sand it with 180 grit, then epoxy, then sandable surfacer before topcoating. Spray can primer is better than nothing, but not much.
JAFO
10-31-2004 21:27:48
 Re: Primer after sand blast in reply to CNKS, 10-17-2004 09:51:28
You probably have to take it down to bare metal and reprimer it. I really doubt the factory primer was waterproof (haven`t heard of any that were) and if it wasn`t, you will have rust under it, even though you might not see it.
