Fresh Air Supply
pat s
10-17-2004 10:40:50
Is there anything special aabout a Hobbyair Compressor. I have 2 compressors. Can I buy a hood and hose and use any compressor?
Rod (NH)
10-17-2004 16:59:09
 Re: Fresh Air Supply in reply to pat s, 10-17-2004 10:40:50
Hi Pat,
Yes, there is something "special" about a Hobby-Air system. It is not really considered a compressor at all but rather a turbine. Think of it as a fan on steroids that develops a few psi of pressure. There are no special filtration devices to maintain (good!) but you must locate the unit in an area where the ambient air that is sucked in the intake is safe to breathe. You certainly can buy a separate hood and a hose but I personally would not recommend you use just any compressor. A dedicated, non-lubricated, tankless compressor is more appropriate (and safer) in my opinion, if you are considering that route. You only need about 4-6 cfm at about 10 psig. See my prior post on the subject. I see that one of the links in that post no longer works, so here is one that shows a commercial compressor-supplied system. It is overpriced for what it is in my judgement.
third party image Rod
loy
10-17-2004 12:12:45
For an air supplied respirator you need at the least an oilless compressor. A turbine system also works well. Think of a turbine system as the output from your shop-vac. I have a SATA system that is approved for an oiled compressor but it is spendy. The benefit is that I only drag one hose instead of two. The fumes from your oil type compressor tank WILL make you sick without the proper filtering cartriges. Loy
