Can you
old
10-26-2004 11:54:02
heat a building with a wood stove and also paint in that building. This building is'nt air tight but it at least can be heated up to arond 60 or so when its below freezeing out.
Michael Soldan
11-02-2004 15:10:37
 Re: Can you in reply to old, 10-26-2004 11:54:02
Old, be careful, paint fumes can be explosive. You could do what you suggested by getting the building heated up, then check off the stove and ventilate the area well as you paint, so long as there is no build up of paint fumes and over spray you should be ok....Mike in Exeter Ontario
