Painting interior of Carb
SproutW
11-04-2004 20:56:54
I'm rebuilding a carb. and I'm thinking of painting the interior of it for rust prevention. Is this a smart move and if it is what type paint should I use. I'm fearful the paint will come off after time with being in constant contact with gas. If paint is bad move what do you guys use to keep the interior from rusting?
pat s
11-17-2004 06:52:59
 Re: Painting interior of Carb in reply to SproutW, 11-04-2004 20:56:54
Don't paint it inside. Use fuel stabilizer in your fuel. It will save you a lot of problems
CNKS
11-05-2004 13:08:23
Absolutely not. Just soak it in carb cleaner overnight and put it back together. Rust is only a problem if the tractor is not run very often.
SproutW
11-06-2004 15:51:42
 Re: Painting interior of Carb in reply to CNKS, 11-05-2004 13:08:23
Thanks CNKS. Kind of figured but thought I would just check to see if things have changed.
