Epoxy primer over old etch primer?
Georgia Boy
11-11-2004 10:00:18
I am getting ready to paint and am using PPG epoxy primer and acrylic urethane. As I dismantled and cleaned the tractor I primed a few small parts with MarHyde self etching primer to help prevent rust (then I switched to Picklex instead). Will epoxy primer go over the etch primer OK or should I go to the trouble of removing it? Or would it be OK to just sand it a bit?
CNKS
11-11-2004 18:54:14
 Re: Epoxy primer over old etch primer? in reply to Georgia Boy, 11-11-2004 10:00:18
I don't know anything about the etch primer you used. MP 170 is ok over the OMNI etch primer, however, so I would guess you are ok -- no guarantees. What you don't want to do is use Picklex followed by an etch primer. If you are using one of PPG's more expensive products, you might check their website, as I am only familiar with Omni.
