recoat Helppppp!!!!!
frankjc
11-15-2004 13:29:38
i used martin senour paint with a hardener, what is the recoat window.a few spots i like to hit again and do i have to suff the paint. its a tractor how am i to scuff this. i painted the main case and axle housing.any help is appreciated!!!!!
Rod (NH)
11-15-2004 18:50:35
 Re: recoat Helppppp!!!!! in reply to frankjc, 11-15-2004 13:29:38
Hi Frank,
I have never used any paints in the Martin Senour lineup but if you used a hardener I don't think you would have a problem. Recoating should be permissible at about any time in that case. The only recoating window problems that I have come across is with epoxy primers and unhardened enamels. You could get the technical data sheet for the exact products you used from the Martin Senour website to verify the absense of any recoat issues. You should scuff the previous film though to obtain decent adhesion of the new coat(s). I would recommend a general purpose (maroon) Scotch-Brite hand pad. They work well with highly irregular surfaces. You really just need to take off the gloss and get a fine scratch.
third party image Rod
