Striped to the Cast Iron... Now ???
The Big C
11-27-2004 16:25:00
The AC Model C is getting stripped down to the Cast Iron with Carb Cleaner (works great) now what is the next step to prep it for painting ??? Next I was planning on cleaning up with lacquer thinner or do I need to degrease it before priming ? Thanks just want the correct paint color to adhere properly this time.
CNKS
11-28-2004 11:37:48
 Re: Striped to the Cast Iron... Now ??? in reply to The Big C, 11-27-2004 16:25:00
In addition to what Rod said, wear a charcoal mask if you spend any time at all with the 330. It does not have a bad odor, but is one of those "use by professionals only" compounds, and can cause brain and nervous system damage. Hopefully that hasn't happened to me, yet, but sometimes I wonder.
Rod (NH)
11-27-2004 17:22:05
Hi,
Here's how I would do it:
1. Lose the lacquer thinner. Use a slow drying specialty cleaner such as PPG's DX330. See "Basics of Surface Cleaners" for some background. Where it is cast iron, I would scrub the DX330 in well with a 3M Scotch-Brite hand pad and wipe as dry as possible with a clean rag while the surface is still wet. Throwaway nitrile gloves highly recommended. Allow a liberal amount of time for any additional drying after wiping. You do not want to trap any of the 330 in the pores of the cast.
2. Prime with an epoxy primer (2 coats) such as PPG OMNI MP-170. Get the tech sheet here.
3. Topcoat within the epoxy window (3 days for the MP-170) with PPG OMNI MTK 60080 acrylic urethane if you have fresh air breathing equipment or with OMNI MAE 60080 acrylic enamel (w/o hardener) if you do not. The 60080 is the early "pumpkin shade" of persian orange used on AC tractors prior to about 1960 - that is, all Bs and Cs. The tech sheets for these products is at the same site noted for the epoxy primer.
third party image Rod
