Farmall 130 Stripe?
Brettjor
11-28-2004 08:09:32
Hello all, I am repainting my 1956 Farmall 130, serial number 952. I have been using a chemical stripper that does a really good job at removing paint one layer at a time. At one time, my tractor appears to have had a white stripe that started at the grill and extended back to the tank across the hood. The stripe ended in a point about 3/4" above where the two halves of the tank join, near the hydraulic controls. The stripe was approximately 5" wide across the entire hood and appears to have been applied at the same time as the factory red paint. Is this stripe original? I haven"t looked at another Farmall 130 in person and I can"t find a good picture of the top of the hood online anywhere.
Thanks,
Brett
CNKS
11-28-2004 11:28:25
 Re: Farmall 130 Stripe? in reply to Brettjor, 11-28-2004 08:09:32
Guy Fay's "Farmall Hundred Series 1954-1958" has a picture. If you go to a bookstore you can probably find others. Or look for the 130 in the "Tractor Photos" on this site. The stripe begins behind the 130 on the hood in the indented portion, and extends back to the raised crease that joins the seam in the gas tank. It does not extend into the gas tank. The stripe was actually a decal, that I believe is still available from Case-IH.
