Dupli - Color Paint
Stan MI
12-06-2004 09:40:40
I was planning on using rattle cans to paint an old truck.
Product"s name is "Dupli-Color", sold through the MEIJER chain.
Anyone ever use this ? If so, results? Also.
Paint is listed as an acrylic lacquer, Am I ok using inside with charcoal mask and good ventilation ?
Rod (NH)
12-06-2004 17:05:13
 Re: Dupli - Color Paint in reply to Stan MI, 12-06-2004 09:40:40
Hi Stan,
I haven't used any Dupli-Color in many years. However, an acrylic lacquer does not contain the dangerous isocyanates so you should be fine. No paint is safe to breath much of though, so yes, a reasonable amount of general ventilation and a decent charcoal type of mask should be sufficient. I believe that can be said for about any rattle can paint, even acrylic enamels. The more serious health concerns come into play with the two-part paints that use a field-applied hardener or activator - that is to say the hardened enamels and the urethanes. It is that separate additive that contains the isocyanates and those paints should only be used with a fresh air-supplied respirator.
third party image Rod
