Removing new paint from serial plate
Derek Hughes
12-06-2004 14:47:05
I've a 1959 Massey Ferguson 35 which has had a bad paint job. The serial number plate has been completely covered in new red paint. Please, does anyone know how to get this off without damaging the original text?
Big Jim
12-07-2004 23:29:23
 Re: Removing new paint from serial plate in reply to Derek Hughes, 12-06-2004 14:47:05
Good old generic brake fluid makes a pretty decent paint remover and it doesn"t work super fast so you have some control. Clean up with water when you are done.
Holger Graulich
12-07-2004 03:39:06
Hallo,
this may not be a real problem. Take a little Acetone (or nail varnish remover) and the paint will be vanished.
mike brown
12-07-2004 15:05:18
 Re: Removing new paint from serial plate in reply to Holger Graulich, 12-07-2004 03:39:06
If the paint is fully cured acetone may not loosen it. Some citrus stripper that you can put on and leave on for a while might do the trick. If that doesn't soften it H.E.T. paint gun cleaner is real aggressive. Don't let it dribble all over the place on the tractor though.
