Haze on new paint job
Bguy
12-08-2004 19:17:54
I painted a Ford 8N last week and tonight I noticed a slight haze in some places, like the rear axle housing. I painted it with PPG MAE with hardner. What could be the cause of this? Can I polish or rub this out?
txblu
12-09-2004 06:04:19
 Re: Haze on new paint job in reply to Bguy, 12-08-2004 19:17:54
Not a painter, but I bet if you put an IR (red) light on it for awhile (without getting it hotter than you can stand to touch) it will evaporate the moisture out and cure the paint simultaneously.
Must have been humid when you painted it. No biggie.
Mark
txblu
12-09-2004 06:06:43
 Re: Haze on new paint job in reply to txblu, 12-09-2004 06:04:19
I'd cook it fore you buff it. Cooking won't hurt and buffing you have to be careful so as to not make the surface finish (sheen) worse than it was when you started. Still take the humidity as the culprit; even if it is solvent, water vapor caused the separation.
Mark
