Bubbles Under My Vinyl Decals
Bob K
02-06-2002 07:32:08
I put the computer-cut vinyl "JOHN DEERE" decals on my hood last night and am having trouble working out a few tiny bubbles (...reminds me of a Don Ho song). Anyway, does anyone have hints on how to get the bubbles out? I've pierced them with a needle but still can't seem to get them to lay flat. Thanks.
Dan Supplee
02-07-2002 17:31:45
 Re: Bubbles Under My Vinyl Decals in reply to Bob K, 02-06-2002 07:32:08
Try a heat gun gently. Next time try wiping the area with a sponge with a little bit of soapy water before applying the decal, then use a body putty applicator to smooth out the decal. This will allow you to move the decal around a little before it is set.
Dan
poorerbut
02-07-2002 06:32:37
BobK: Not 100% guaranteed but, sometimes, if you can direct hot air, (like from a hand-held hair
dryer)after you pierce the bubbles, you can
smooth them out with a plastic or teflon spreader
(like the kind you spread epoxy with).
Only a thought. Luck. pb
poorerbut
02-07-2002 06:29:37
