Paint Flashing??
Chris Willy
12-14-2004 18:22:44
This may be a dumb question as I"ve done quite a bit of painting over the past 4 years, I have heard some guys talking about letting the paint "flash", could someone please tell me what this means, thanks alot. Have been curiuso for a while wondering what it meant.
Thanks
CHRIS
Frank Stalfire
12-14-2004 18:56:43
 Re: Paint Flashing?? in reply to Chris Willy, 12-14-2004 18:22:44
HI Chris
Paint will either "dry" or "cure". paint dryes when the solvents in it evaporate and leave behind just the solid material, paint cures when the isocyanates in it cross-link with the moleculs of resin and the solvents evaporate. Solvents evaporate in 2 stages, a large surge of solvent immediatly after application, and a slow time released evaporation that takes about 3 months, when you wait for a coat of paint to dry before the next coat you are waiting for the "surge" to release, the " surge" is also called a "flash" of solvents, thus the phrase " letting the paint flash". Hope this helps.
Frank
Chris Willy
12-14-2004 19:01:52
 Re: Paint Flashing?? in reply to Frank Stalfire, 12-14-2004 18:56:43
Thanks Frank, that helped alot, so its basically the same as meaning when you can pretty much touch the paint?
CNKS
12-15-2004 06:05:29
 Re: Paint Flashing?? in reply to Chris Willy, 12-14-2004 19:01:52
Sort of, the time you are referring to is usually 10-15 minutes with quality paint at 70 degrees. If you've painted a lot, you already know that.
Chris Willy
12-15-2004 06:29:10
 Re: Paint Flashing?? in reply to CNKS, 12-15-2004 06:05:29
Yup that's what I meant, thanks guys.
Chris
