Tractor Paint,
Kirk C,
12-24-2004 11:47:58
Can I use 600 wet or dry to strip paint off sheetmetal,?
I did this to a 52 8N Ford one time,and it worked pretty good,(But,I got the light Red,
when I should of got the Dark Red, I have Massey 2700 Series,w/ Silver Cab,
The Paint is starting to go away on the top of Cab Side,s,& the grab Iron,s,
Showing Surface Rust,I guess do that w/ 600 too,and it will be ok?
Need Help!
msb
12-24-2004 13:39:09
 Re: Tractor Paint, in reply to Kirk C,, 12-24-2004 11:47:58
You can but it is a very slow way to do it.I use paint stripper where I can and take all the painf off down to the bare metal.That way all the rust is exposed.Treat the bare metal with rust stop,prime and shoot with a little sanding between coats .Might not be the way pros do it but it works for me.
