Small quantity paint over OMNI 170?
Paul_NJ
12-24-2004 14:11:57
Can someone recommend what rattlecan paint I can use that is compatible over OMNI 170 epoxy primer?
I'm planning to paint my International 340 priming everything with 170 epoxy primer, and topcoated with MTK. For the basic body coat, I'll purchase a gallon of red, and quarts of white and silver for the trim and wheels. But since I only need black for the dash panel, I hate to buy a whole quart.
Any suggestions?
CNKS
12-26-2004 09:14:22
 Re: Small quantity paint over OMNI 170? in reply to Paul_NJ, 12-24-2004 14:11:57
If you have the panel off and mess up, it is easy to repaint. If I wanted to use a rattle can, I would just buy the best paint I could find. I don't believe the 170 will give you problem, although when I have used rattle cans on small parts, I usually use rattle can primer made by the same company. Otherwise you can bite the bullet and buy a pint of MTK. Expensive, but you will be sure of the results.
