Electrolytic Rust Removal Question
Mike
02-10-2002 09:52:16
I'm looking for some ideas on what kind of electrode to use. What would make a good one? Does the part your cleaning have to make contact with the electrode?
Franz
02-10-2002 21:35:55
 Re: Electrolytic Rust Removal Question in reply to Mike, 02-10-2002 09:52:16
old lawnmower blades, spring leaves, sheet metal, almost anything you have available.
The biggest consideration, surphace area should be equal to the item you are derusting.
Don't forget to clean the anodes off regualrly.
anothre doug
02-11-2002 05:18:55
 Re: Re: Electrolytic Rust Removal Question in reply to Franz, 02-10-2002 21:35:55
I'm using an old plow share, the bolt holes are easy to get the clip terimal onto...but had to shut down due to cold weather (she froze solid)
Jerry B
02-10-2002 12:28:12
Use Stainless steel and NO the parts do not touch.
