Clear Coat Vs. Decals
Robert in NC
01-17-2005 13:28:46
I have heard many different opinons on whether or not to used a clear coat over decals. Can you guys tell me once and for all what your thoughts are on the subject or personal exp. that you have had with using a clear coat over the top of your decals? Would like to fresh paint coats but don't want to ruin my tractors decals either.
Big Jim
01-19-2005 22:47:33
 Re: Clear Coat Vs. Decals in reply to Robert in NC, 01-17-2005 13:28:46
Shoot a test panel first is the best advice ever given.
From the pros I've read: clearing decals is generally a good idea, both for looks and lifespan. The preferred method seems to be to clear the whole surface with several coats, wetsand the decal area to thin the clear and minimize the sharp edges around the decals, then clear everything again. This gives an almost smooth final finish and decals that look like paint. My wife's PT Cruiser has extensive flame decals and I plan on clearing them this summer.
Does depend a bit on how much effort you want to put into the whole job. A working tractor is a bit different than a show paint job.
Rod (NH)
01-17-2005 19:27:27
Hi Robert,
I have had good success using a urethane clearcoat over cut vinyl decals. I think it makes them look a little more like actual painted-on letters since it tends to blend the sharp edges slightly into the surrounding area. It also provides some limited physical protection to the decal. A finishing touch if you will. I have only used this combination over a urethane single stage color that was compatible with the clear coat and that was applied within the clearing time window of the color coat. In my case that was 4-6 hours after application of the color coat. I am aware that some decals advise against application prior to full cure of the color but if you are going to clear without scuffing the color (at least in urethane) you don't have much choice. Some enamels, especially those w/o hardeners may not fair well with another coat of anything that soon so make sure you are using compatible color and clear materials that are of the same manufacturer and that are specifically recommmended for use together. Anything else is a crap shoot unless you find someone that has done it successfully with the exact same materials and process. You could also do a test sprayout and waste a decal just to be sure. That's what I did. In any event, a clear coat is not necessary and I suspect that most don't bother to do it since it adds time and cost for somewhat minimal benefits.
third party image Rod
