Hi Steve, Acetone is becoming more and more prevalent as a paint thinner or thinner component because of increased air emission regulations (VOCs). It is a solvent that is exempt from regulations. Don't ask me why it's exempt. I'd like to know myself. Rustoleum products used to have their own proprietary "thinning oils" and cautioned not to use anything else. I am not a fan of Rustoleum for spraying so I have no experience in "experimenting" with it. The best I can recommend is to follow the label instructions. Anything else is somewhat of a crap shoot unless you can find someone else who has done successfull experimenting with the exact same components. Acetone is a fast evaporating solvent so you might try uping it to the recommended maximum 15% ratio. Also review this regarding orange peel, courtesy of Martin Senour: ******************* ORANGE PEEL ( Poor Flow, Texture) Paint film having an uneven texture that resembles the skin of an orange. CAUSE (A) Under reduction and/or air pressure too low. (B) Thinner/reducer evaporates too fast for spray conditions. (C) Excessive film thickness or piling on of heavy wet coats. (D) Improper spray gun set-up. (E) Improper painting technique. REPAIR (1) Compound or polish to reduce surface texture. (2) Or, sand smooth with 1200 or finer grit sandpaper, compound and polish to restore gloss. (3) Or, sand smooth and refinish. PREVENTION (A) Use proper reduction ratio and spray at recommended air pressure. (B) Select recommended thinner/reducer based on temperature, humidity, air movement, and size of repair. (C) Avoid heavy coats and excessive film thickness. (D) Use recommended spray gun, fluid tip and air cap for the material being sprayed. Always adjust the gun for best atomization and balanced spray pattern before paint application. (E) During paint application, hold the gun perpendicular and parallel to the surface. Adjust speed of pass, pattern overlap, and distance from the panel to achieve the desired appearance. **************** Be sure to check the air pressure directly at the inlet to your gun. Install a pressure gage right at the inlet as shown below and check the pressure with the trigger pulled. Make sure the fan pattern adjustment screw is wide open and the fluid control adjustment screw is also wide open. There does not have to be any paint in the gun to do this. Set the pressure using whatever regulator you have back at your compressor. Never mind the pressure at the regulator. It's the pressure right at the gun inlet that counts. An HVLP gun should have the "maximum" pressure indicated on the handle or in the instructions that came with it. It typically will be about 30 psig but could be anything from 15 to 50 psig. Set the pressure at least to that number. If that doesn't do the trick try going 5 or 10 psig higher (if you are not regulated by some law in your area) to get a little better atomization. If you still can't get it to work well, I'd look at using a different paint.
Rod
