supplied air hood .cant see out of mask ,getting r
tommyw
02-03-2005 05:06:37
i have the sas pro model full face mask .it looks like a gas mask .im haveing trouble with the lens fogging on the inside ,and just generally cant see good enough to paint correctly. i have painted for 20 years ,and the other day i got a run on a tractor hood that was 1 foot long with icecycles all the length .im a beliver that it makes you feel better ,but now i know why i never used it (cost 1500$) . are the hoods any better ? thought about another sandblasting helmet ,i can always see out of it ,but i would need a clean one to paint in.
Mike S 806/H
02-07-2005 22:06:18
 Re: supplied air hood .cant see out of mask ,getti in reply to tommyw, 02-03-2005 05:06:37
I have the same mask , be sure the nose piece is fitting right. If there is a leak it will fog
Big Jim
02-03-2005 23:59:50
Since I wear a full beard, I was kind of forced to choose a hood and I"m glad I did. The air flows in the back, over your head, and down across the lens. Zero fogging problems. It is also very light and comfortable.
CNKS
02-03-2005 07:26:36
I have a Hobby Air, no fogging. Check the link below and call Len Stuart (it's his business). The Hobby Air hood may adapt to your system, Len should know as he sells both of them. The hood I have is nothing more than a tyvec hood, no mask, works fine.
tommyw
02-05-2005 07:56:25
 Re: supplied air hood .cant see out of mask ,getti in reply to CNKS, 02-03-2005 07:26:36
the mask i have is very simular to the 1F model ,sure makes me feel better after painting ,but if you cant see well it is hard to paint right.ill get a hood and try it ,ill bet my local dist. can get an sas model.,thanks for the replys .
