primer on engine
scott0618
02-05-2005 10:09:48
I am going to be painting a Farmall Super C soon, and was wondering if I should use a "high heat" engine primer - on the engine, or will a oil base primer be ok?
Thanks!
Rod (NH)
02-05-2005 13:44:16
 Re: primer on engine in reply to scott0618, 02-05-2005 10:09:48
Hi Scott,
You shouldn't need any special high heat primer on the engine (with the exception of the exhaust manifold itself). Use whatever primer is recommended by the manufacturer of the topcoat you are using.
third party image Rod
