Primer under PPG Epoxy
Daniel H.
02-10-2005 19:20:23
I plan to plan to paint my Cub with PPG Delstar when I finish the restoration. I was going to use their epoxy primer but the recoat window is 7 days. I need to protect the small parts as they come out of the sand blast cabinet. It could be several months before I have everything ready. Would it be ok to use a rattle can primer or even a gun primer UNDER the epoxy to keep the parts from rusting. What should I use? It says you can sand and recoat the epoxy just before top coting, but I don't think sanding cast iron would work very well. Thanks.
CNKS
02-10-2005 19:46:28
 Re: Primer under PPG Epoxy in reply to Daniel H., 02-10-2005 19:20:23
My answer to that question is no. You are using expensive paint, don't mess it up with cheap rattle can primer. Epoxy is designed to bond with the bare metal. While it can be used over old finishes, that assumes the old finish is well bonded with the metal, not so with rattle can. You don't have to sand the epoxy, just use scotch brite pads and recoat. Nooks and crannies may be hard to get to, but it should work -- but, I have never done it, but I have done lots of scuffing to remove Picklex residue--see next sentence. Your other alternative is what I usually do -- use Picklex 20 which is a phosphoric acid/zinc rust protectant. It will kill any residual rust and protect the metal for months afterward, if kept dry, it is not waterproof, epoxy is. Will likely leave a white residue, most of which can be scuffed off with scotchbrite pads, then treated with DX 330 before applying epoxy. It (Picklex) is applied with a squirt bottle and then brushed. That said, I currently have several bare metal parts, that have sat since November with NO protection -- there is no visible rust on them, I live in a dry climate, but we have had several spells of wet weather. I don't worry too much about rust. Picklex does react with the cast, when cleaning up with DX330, it takes several applications before the rags come back clean.
moseed
02-11-2005 06:53:14
 Re: Primer under PPG Epoxy in reply to CNKS, 02-10-2005 19:46:28
The Picklex 20 info. says you can paint over the residue left after treatment. Is there an advantage to removing it before priming?
CNKS
02-11-2005 08:09:16
 Re: Primer under PPG Epoxy in reply to moseed, 02-11-2005 06:53:14
That's what it says, may or may not be "sales talk". I just don't like painting over any type of residue. The white powdery residue that Picklex leaves can be removed with your fingernail -- to me that is not a good sign. I don't know whether epoxy primer will bond to that type of surface. Also the whiter the surface, the "dirtier" the metal. I am far from an expert, but I remove as much as I can, just to be safe.
