ful-thane question-opinions
Tim...Ok
02-17-2005 09:05:56
Just off,thanks Rod for you help the other day..Second,I got the ok from an old buddy of mine to use his paint booth with supplied air system,so this changes everything.. I already bought the Ful-poxy 491-16 primer,now I"m thinking of going with the Ful-thane 3.5 high solid urethane that doesn"t require a sealer under it..Any of you ever used this stuff?? From what I"ve read,it sounds like pretty good stuff..I ordered it earlier today,but probably could still cancel it if I needed too..Any and all opinions welcome..
Thanks,
Tim
Frank Stalfire
02-17-2005 12:46:14
 Re: ful-thane question-opinions in reply to Tim...Ok, 02-17-2005 09:05:56
It's the best Nason has to offer, it's got good solids, great gloss retention and will perform better with Dupont premeir reducer, just replace the reducer with DuPont Chroma preimier reducer 12385,, you can go to www.performancecoatings.dupont.com for tech sheets.
Tim...Ok
02-18-2005 05:18:23
 Re: ful-thane question-Frank in reply to Frank Stalfire, 02-17-2005 12:46:14
Are you saying I should use that 12385 only,or should I use one from that line that fits my temp requirements?? I may try spraying a little this weekend,supposed to be pushing 70 degrees. Another question,Rod suggested thinning the PPG epoxy with up to 10% acetone for the final coat to use as sort of a sealer,the nason epoxy spec sheet doesn"t say anything about thinning,do you know of a compatible "thinner" for the Nason epoxy..Sorry for silly questions,I"m learning alot and new to this painting stuff :-) Thanks,
Tim
Tim...Ok
02-18-2005 04:49:03
Thanks,
Tim
Frank Stalfire
02-19-2005 07:01:11
 Re: Frank in reply to Tim...Ok, 02-18-2005 04:49:03
Sorry not to get back sooner, as for reducer use whatever temp range you like, what I meant was the nason is more of an economical line and part of the way to get prices down is to use more economical solvents, using Preimier solvents will give a more appealing final finish, it won't add dourability or anything like that. as for thinning epoxy, I don't really have any thouhgts on that since i have never tryed it,If Rod has tryed it and had sucess then he would be the man, just be sure whatever you do not to add to much because you will loose the characteristics of thre product
Tim...Ok
02-21-2005 05:15:08
 Re: Frank in reply to Frank Stalfire, 02-19-2005 07:01:11
Thanks Frank, I"ll give the Premier a try..
Tim
