Paul, PPG's DX579 is not intended as a rust preventative. It's a metal cleaner that can remove light incidental rust as part of a two step process in preparing bare metal for painting. If you follow PPG's recommendations for use, the DX579, after rinsing, should be followed with DX520, metal conditioner and then after a second rinsing, primed the same day. These are products that are intended to etch and condition the metal for essentially immediate painting. They both contain phosphoric acid but so do many different products that somehow deal with bare metal and rusting. I have used them in the past but they are messy to bother with. On surfaces that are sandblasted to bright metal, they are not recommended at all by the company (Henkel Surface Technologies) that supplies them to PPG. As you suggest, not all products that contain phosphoric acid in varying amounts are the same. My work now that is sandblasted gets an epoxy prime the same day with no chemical prep. I reserve the phosphoric acid prep with the DX579/520 (or equivalent DuPont products) for smooth bare steel (not sandblasted) that I don't want to sand enough to require the use of a surfacer after epoxy. Chemical stripping of decent sheet steel that otherwise requires no bodywork would be an example. I have a similar problem to yours though when it comes to cold weather. I purchased some Picklex 20 last fall to use this winter after some sandblasting of small parts so I could defer the actual priming till warmer weather. That plan has not worked out yet since I have done no blasting in my cabinet, even though I wanted too. It's been too cold plus there have been other priorities. I know CNKS has had good luck that way with it and that's what it is advertised to do. That's why I bought some. I purchased it from autobodystore.com. I used to have a link to the actual application instructions but I can't seem to locate it. It did say it was OK to use on sandblasted steel. Here's a basic info sheet on the stuff however. Rod
