Big Dent
Maurice
02-18-2005 17:49:48
I am in the process of restoring a 1410 Case David Brown. The front hood bonnet has a big deep dent in it. The size of a Basketball. What would be the best way to straighten it out???Take a hammer and beat it out??? I am new to paint and body work and wasn"t sure which would be the best way to go.
Thanks for any advice in advance.
Maurice
dr.sportster
02-22-2005 15:34:50
 Re: Big Dent in reply to Maurice, 02-18-2005 17:49:48
Hi Maurice,Im back with more bad advice.If you do try it get a book and study it. Get the proper dolly and hammer.There is an orderly way to attempt this.Kind of like reversing the way the dent happened.But as I said earlier if the metal is streched at all forget it.
maurice
02-22-2005 16:49:57
 Re: Big Dent in reply to dr.sportster, 02-22-2005 15:34:50
Thanks for the info dr.
maurice
02-22-2005 16:49:43
dr.sportster
02-20-2005 07:54:48
When you take it to a body and fender man hang out and watch him.This way you wil say wow I never could have done that the right way.If the metal is stretched it takes experience and is better to pay an expert.My body and fender guy amazes me with his skills at dent removal.Good Luck
rustyj14
02-18-2005 18:14:51
Remove the hood, take it to an auto/ truck body repair shop and pay them to repair the hood, and put it in primer. And/or have them mix up paint to match and paint it the correct color! Believe me, if you take a hammer and beat out the dent, you'll end up with a knot in the hood, that no amount of work will ever be enough to make it right again! How do i know this? From 50 + years of auto and truck body work! I've had guys bring their cars in for an estimate, and then later when they bring it in for me to fix it, i find they've beat it out with a red brick and a stick, or a large hammer and a screw driver, (same thing), at which point i'd tell them to take it to the guy who started the job--don't bother me! moral of the story: If you aren't well experienced in body work, leave it to the experts! by: rustyj
Josh U
02-22-2005 17:20:04
 Re: Big Dent in reply to rustyj14, 02-18-2005 18:14:51
How will anybody ever get experienced unless they try? I wouldn't reccomend starting on something as major as a hood, but you could even get an old car fender or something you don't care about and give it some dents then try to fix them.
rustyj14@yahoo.com
02-27-2005 11:47:00
 Re: Big Dent in reply to Josh U, 02-22-2005 17:20:04
Yes, that's the right way to get experience at body work. go down to the local auto body shop and ask for an old fender and/ or hood. take it home, then get some practice at repairing the part. you'll soon see why i reccommended what i did! Looks easy/ is danged hard to do! But, with practice, and lots of plastic filler and elbow grease, and patience, and cussing, you will decide i'm correct! It took me 2 years to get enough experience to repair a dent in a fender, where i worked! The dent has probably stretched the metal, so, if you get behind it and bang it out, you'll end up with a large hump, instead of a dent! there is a process called shrinking metal, but i'm not going to go into that here! there is also a process of working the metal back into the approximate level, then filling with automotive body filler (plastic), board sanding it down, priming it, etc. Check with CNKS in this forum for the info on paint, primer, fillers, hardeners, etc.! I've been out of the auto body trade too long to be able to tell you what you need to know! Everything has changed since then! by: Rustyj
