odd paint prep question
mikeinWA
02-20-2005 23:25:07
Finished a restoration recently on a SA. Dry fit all the tin and farmed out some things to be sand blasted. Long story short, after paint and reassembly the tank leaked like a sive. Wish I had checked after sand blasting and before paint, but lessoned learned. Any way I lined the tank and it is holding fuel, but it was soaked in a hot tank and the paint is blistered. My question is what next? Can I sand and reprime, or does the process of soaking in a hot tank require another treatment to get paint to stick?
CNKS
02-21-2005 07:16:47
 Re: odd paint prep question in reply to mikeinWA, 02-20-2005 23:25:07
Sand it throughly, clean it good with PPG 330 wax and grease remover, and prime with epoxy. The prep will remove any contamination from the hot tank. As a precaution, also throughly clean with soap and water, then DX 330 BEFORE you sand.
mikeinWA
02-21-2005 09:28:23
 Re: odd paint prep question in reply to CNKS, 02-21-2005 07:16:47
As always, thanks for the help. If just one person reads this thread and tests their tank after prep and before paint I'll feel better about having made the mistake myself.
Mike
