skim coat
S. Thomas
02-21-2005 14:57:43
I need to skim coat a couple of fenders for a tractor. Is there another product, other that Bondo. I have to mix up, so many little batches it very time consuming.
Josh U
02-22-2005 17:07:03
 Re: skim coat in reply to S. Thomas, 02-21-2005 14:57:43
If you lay on several coats of high-build urethane primer than sand it down it can fill even fairly major pitting. We us a product called URO-Fill which builds great and is very easy to sand.
Frank Stalfire
02-21-2005 19:51:46
you can use a sprayable polyester like Featherfill, or Spies Hecker 3508 or Standox Spraypoly, these polyesters can build up to 40-60 mills, there are some down sides, they can not go direct to metal and conot be put over an acid containing product, and cannot be directly topcoated.
Frank
