wiring diagram
dan rausch
02-24-2005 15:47:05
I own a 1953 allis chalmer wd45. Just put rebuilt generator and regulator on it, this is the old cut out type regulator. When the tractor is running if i take the wire off the battery the tractor dies. I assume if it is generating it should keep running off generator. I need a wiring diagram to check the wiring I think. Any advice would be helpful. thanks
dan rausch
Max IN
02-24-2005 19:01:08
 Re: wiring diagram in reply to dan rausch, 02-24-2005 15:47:05
Dan Can send you a wiring diagram for dw45 by fax if you can get me anumber
