Priming ahead.
jc newton
02-26-2005 17:39:48
I am going to tear down My tractor 1 piece at a time. I would like to clean and prime as I go . On the small parts I would like to use a primer out of a spray can so I would not have to clean up after each piece. Is this o.k. to use? I may not get around to the fimish coat for a while but it would be in a dry location.
CNKS
02-26-2005 19:01:43
 Re: Priming ahead. in reply to jc newton, 02-26-2005 17:39:48
No. Either use epoxy primer with a spray gun, or use a rust protectant such as Picklex 20. In addition to the spray can primer being of low quality, it may not compatible with the topcoat you decide to use.
bobB
02-28-2005 16:25:41
 Re: Priming ahead. in reply to CNKS, 02-26-2005 19:01:43
Doesn"t the epoxy primer need to be top coated within a short time after application? If so, you probably wouldn"t want to leave yor parts sit around several months before painting them.
CNKS
03-01-2005 17:33:35
 Re: Priming ahead. in reply to bobB, 02-28-2005 16:25:41
Has to be scuffed and reapplied.
