tractor paint
fergy nut
02-27-2005 03:23:24
I have a 2775 Massey,and it was sitting out some of its life,
some painted parts are getting that brown color on them,not bad ,but just on the surface,
how do I get that off?
Will fine compound work?
& then go over it with a wax cleaner?
to clean it up?
get back to me on this ok somebody,
thanks, fergy nut
VaSlim
03-09-2005 22:03:24
 Re: tractor paint in reply to fergy nut, 02-27-2005 03:23:24
Go to the Implement Alley discussion forum and do a search on Ospho. There is a discussion there about using diluted Ospho to remove paint oxidation. Might be what you are looking for.
Rod (NH)
02-27-2005 09:17:21
Hi,
If by "brown color" you mean rust is showing through whatever little paint you have remaining, I don't think there is any easy fix. The parts would need to be completely stripped, all rust removed (sanding/wire brushing/chemical treatment/sandblasting, etc) and the parts properly primed and painted. However, I may not be understanding your situation correctly.
third party image Rod
