Frank Stalfire
EX-pro
03-01-2005 09:36:45
Do you have a color code for flambeau red in Imron 5000? How many variants are there?
JerryB
03-08-2005 14:27:01
 Re: Frank Stalfire in reply to EX-pro, 03-01-2005 09:36:45
Look up 1976 Chrylser V1 code. It is listed as an alternative shade of Flambeau Red.
The full list of codes is:
7505
44128 (Mopar V1 code)
75195 (Prices out in Centari and Imron) Chroma Base lists it as cost code M (AS in $Money)
EX-pro
03-08-2005 15:52:45
 Re: Frank Stalfire in reply to JerryB, 03-08-2005 14:27:01
Thank you. Just what I needed.
Frank Stalfire
03-01-2005 19:33:03
Sorry I don't have the ability to look up color by name, if you know what it originally came on, dodge,ford,chevy ect, or a paint code or a competators paint code I may be able to help
EX-pro
03-01-2005 21:54:30
 Re: Frank Stalfire in reply to Frank Stalfire, 03-01-2005 19:33:03
It's for a Case. 066DH and TP140 are the codes I see. Are these good codes for 5000? If there are several variants, I'm looking for the least orange of the formulas. Thank you.
rustyj14@yahoo.com
03-03-2005 12:16:08
 Re: Frank Stalfire in reply to EX-pro, 03-01-2005 21:54:30
Some of the better auto paint stores have a computerized machine that can be run over the existing paint, and it will make up a paint formula for that color! If you have a panel you can take off, clean it up good with rubbing compound, then take it down and see if they can come up with a match for it! i had some paint mixed for a paint color that i had mixed up by using 2 colors of blue, and the resulting paint matched perfectly! BY RJ
rustyj14@yahoo.com
03-03-2005 12:16:00
Frank Stalfire
03-03-2005 19:41:17
 Re: Frank Stalfire in reply to rustyj14@yahoo.com, 03-03-2005 12:16:00
This option Rustj mentions does work well provided you have a sample to take a picture of, if you do you may want to give it a try, also stick to solid colors, the camera cannot read mettalic flake size and shape.
Frank Stalfire
03-02-2005 19:47:22
Sorry I should have explained better about the codes, only auto and truck applications will have a code for the paint color, tractors if they are old you will have to tell me the year and model and if they are new I can look at my database which does show 2 reds one is "Case red" and the other is "Grafic Red" unfortunetly there is no other info for those reds so you would have to get a small amount of each and spray them on a small panel and see which one matches, again if it is an old tractor I might have better luck
Frank
