what paint?
Tim Shultz IN
03-08-2005 17:53:57
I need to know what brand of paint to use for tractors/truck? I am in the dark so any help would be great!
Tim
M77
03-09-2005 18:56:12
 Re: what paint? in reply to Tim Shultz IN, 03-08-2005 17:53:57
I respectfully disagree concerning BPS paints manufactured by Valspar and sold by TSC. First thing, I am not affiliated with their company or Valspar.
I am a professional painter (recently retired) and have used everything from House of Kolor, PPG, Sikkens, Glasurit, Dupont and certified with the above. I was also an instructor with the I-CAR certification process.
Here it is: When the surface is prepaired corectly, and primed with the BPS primer and hardener added, it is, quite literally on there forever. Exactly the same process applies for the topcoat (color coat) when the paint is properly reduced with up to 5% Naptha, and up to 30% hardener it will not fade, chalk, chip and the gloss retention and durability are outstanding. This paint is Bulletproof. I have painted all our tractors with these products for the last 14 months....and it is 1/10th the cost of high end automotive acrylic enamels and holds up as well and usually better.
Like you and many, I was not a believer untill I contacted Valspars' BPS technical representative, and found out the proper reduction rates, catalyst amounts and how and why it works so well.
Regards, Mark
CNKS
03-12-2005 20:02:50
 Re: what paint? in reply to M77, 03-09-2005 18:56:12
14 months isn't very long -- and it's still synthetic enamel, it will fade unless kept inside. Of course you can keep it waxed and make it last much longer, just like I used to do the 50's-60's cars, which had essentially the same stuff. Newer paints simply need less maintenance.
Bob T.
03-09-2005 12:27:18
I have had good luck with Rustoleum Oil based paints on farm machinery. If gettting the "exact" color is not an issue. They last much longer than TSC but not as pricey as PPG etc. I would not paint a truck with it though. For a sickle mower etc. as you describe, it will be fine, especailly if you keep it inside afterwards. They have a green that is very close to Oliver, and a Red that is dead-on New Holland for example. Rustoleum discontinued their "actual" machinery paint a few years back. I actually prefer to brush paint implements with limited sheetmetal such as plows. I use NO thinner and apply it thick, and it fills in rust pits well and if you "tamp" after dragging the brush, the lines won't show. Hope this helps!
Rod (NH)
03-08-2005 19:05:44
Hi Tim,
Not knowing what your goals are or what kind of money you want to spend, I'm going to say an acrylic enamel in any automotive "economy" paint line. The particular brand is not important. It's whatever is available locally in your area. PPG OMNI and DuPont NASON are the big ones. Martin Senour (NAPA) also has a competitive line but I don't know the name of it offhand. There are others but they do not market in my area and I have no detailed knowledge their products. I am sure they are competitive for a similar cost/quality paint. I am assuming here that you are talking a spray application, not brush.
third party image Rod
Tim Shultz
03-09-2005 07:26:47
 Re: what paint? in reply to Rod (NH), 03-08-2005 19:05:44
I just need some paint that will last, don't got to be real nice lookin. as for brush or spray...
I have a sprayer but freind of mine said to brush it on, would that be O.K? the first thing I am going to paint is a sicle bar mower.also I don't want it turning PINK in a year! lol
I can get TSC's paint cheep, but I heard it is crap, any thoughts? I was told to get paint from NAPA, money is short right now soooo..... ..
Tim Shultz
Don-Wi
03-13-2005 10:31:09
 Re: what paint? in reply to Tim Shultz, 03-09-2005 07:26:47
To avoid fading, use a clear coat. I just used 2 rattle cans on an old runnnig gear after painting it red with F&F oil-based enamel a few years back, put a really light coat of clear on it and it still shines pretty good, unlike the hay rake I painted w/out clear out of that same gallon of paint. It's faded to pink and the yellow is almost white. Clear coat is the key to not fading, or atleast putting it off for a while
Donovan from Wisconsin
Don-Wi
03-13-2005 10:29:56
JerryB
03-09-2005 11:56:51
TSC paint IS crap compared to about anything else. However if you are just trying to preserve the metal it will work. It WILL chalk and lighten in a matter of a few months.
The biggest problem in using that cheap paint is you can't paint directly over it with any kind of "hot" automotive type paint within about 2 years. It can be catalysed to make is cure and harden much quicker, but if you have to go to all that trouble why not just go one more degree and paint with a good paint?
IMHO
