How do I get it to shine????
Luke Rhonemus
02-19-2002 18:03:31
I have just finished a 730 John Deere and it is the first paint job I have completed. I did great on the body work and all but my final shine just isn't pleasing to me. I have some other tractors to paint and before I do, I want to get others' opinion on what to use. I use JD paint and JD thinner. Should I use automotive thinner to get the gloss look? Hardener maybe? If so what type and how many parts of thinner per paint should I use? I will ONLY use Deere paint. Thanks and any tips at all on priming or painting are gladly accepted. Luke
terry
02-20-2002 16:53:05
 Re: How do I get it to shine???? in reply to Luke Rhonemus, 02-19-2002 18:03:31
colorsand it and buff it,you could even sand the paint with say 2500 gritt sand paper and hand rub the shine into it if you feel like getting big muscles
Wilham restorations
02-20-2002 09:07:15
use your j.d. paint with hardener (dupont#77s) or any ones that for alkilyd paint if your tring to paint the whole tractor you will have to slow down the reducer.what you got is a over spray problem the reducer is to fast hope this helps if been painting for 20 years all over the mid west KEVIN
Stara Auto Body - Restorations
02-20-2002 09:47:40
 Re: Re: How do I get it to shine???? in reply to Wilham restorations, 02-20-2002 09:07:15
You will want to use hardner designed for synethic enamls because this is what the JD paint is. Mar-hyde or martin senour paints makes hardner. Next you will have to give the sheet metal 3 coats of paint with the last coat mixed alittle thinner. We have painted over 55 tractors, of all makes and models, and unless you use hardner and 3 coats you will not get a very good shine. RS
02-20-2002 09:47:21
cd
02-21-2002 16:48:01
 Re: Re: Re: How do I get it to shine???? in reply to Stara Auto Body - Restorations, 02-20-2002 09:47:21
dont you mix thinner into every coat of paint or did you mess up the post and meant to say hardener? without thinner you get orange peel and the gun wont even suck some stuff up like that.
Stara Auto Body-Restorations
02-21-2002 23:13:18
 Re: Re: Re: Re: How do I get it to shine???? in reply to cd, 02-21-2002 16:48:01
Yeah sorry I messed up, I use thinner in every coat, but i use a extra oz. on the final coat.
cd
02-22-2002 14:08:45
 Re: Re: Re: Re: Re: How do I get it to shine???? in reply to Stara Auto Body-Restorations, 02-21-2002 23:13:18
ok i wondered, thanks because i will use that advise too, is it ok to mix clear and color; will it be nice that is? or a waste?
Stara Auto Body
02-22-2002 14:43:33
 Re: Re: Re: Re: Re: Re: How do I get it to shine???? in reply to cd, 02-22-2002 14:08:45
Which paint are you going to use. JD or Dupoint or PPG.
cd
02-22-2002 17:14:05
 Re: Re: Re: Re: Re: Re: Re: How do I get it to shine???? in reply to Stara Auto Body , 02-22-2002 14:43:33
not any particular, lets says 2 examples JD and Martin Senour Synthol Enamel.
02-21-2002 23:10:17
Rod (NH)
02-20-2002 08:14:00
I recommend you use ONLY whatever thinners and/or hardeners, including mix recommendations, are called for on the JD paint label. You should also check the label on any hardeners that you may use to see if they contain isocyanates. If they do, you should use a supplied-air respirator (not a chemical cartridge one) to protect your respiratory system. The stuff is very toxic.
