cleaning after sandblasting
jr55
03-15-2005 17:11:13
I have a tractor apart, I mean completely apart. I am sandblasting it piece by piece. How do you get all the sand out of the parts, and is it ok to prime next or should you do something else first?
CNKS
03-15-2005 17:24:48
 Re: cleaning after sandblasting in reply to jr55, 03-15-2005 17:11:13
Sand is imbedded in all the parts. I use a wire brush on an angle grinder. You can use sandpaper if you also blasted the sheet metal. Then clean with a wax and grease remover, go over them with a tack rag, then prime with epoxy primer.
