One Stage vs. Two Stage Compressors
JKC
03-21-2005 16:08:19
I have been told that I need a 2-stage air compressor for my blasting cabinet. Can anyone tell me the difference between a single-stage and two-stage air compressor? Any help would be greatly appreciated.
Frank Stalfire
03-21-2005 20:01:19
 Re: One Stage vs. Two Stage Compressors in reply to JKC, 03-21-2005 16:08:19
single stage just produces airr thru normal piston travel, 2 stage compress', then compress' again making the desired air pressure faster
Rod (NH)
03-21-2005 20:24:55
 Re: One Stage vs. Two Stage Compressors in reply to Frank Stalfire, 03-21-2005 20:01:19
Sorry Frank. My post was meant to respond to JKC and not you.
Rod (NH)
03-21-2005 20:22:33
Hi JKC,
You don't need a two stage compressor to serve a blast cabinet. You need appropriate capacity in cubic feet per minute (cfm) at about 100 psig minimum, usually. A single stage compressor can easily do the job if it has enough piston displacement. Personally, I would want a minimum of about 15 cfm as a reasonable capacity for a blast cabinet. A lesser amount can be made to work, but would require a small nozzle and take a longer time, even for relatively small parts. Blasting is one of those cases where bigger really is better.
A single stage compressor compresses air in one shot from atmosphere to a maximum of about 135 psig. Higher pressures are usually not practical in single stage because of the very high temperatures involved. They are caused by the higher compression ratios needed to go higher in pressure in a single step. For example, the compression ratio in a single stage operating at 135 psig is about 10:1.
A two stage compressor compresses air in two stages. In reality, it is like two single stage compressors run in series, with the second one being smaller in displacement than the first one. The first stage compresses air to some intermediate pressure, usually about 40 psig maximum. Then the air is cooled by an intercooler (usually a length of finned tubing) and sent to the second stage where it is increased in pressure, usually to a maximum of 175 psig. The compression ratios when operating at 175 psig are about 3.5:1 for each of the two stages. Because of the higher maximum operating pressure, more air can be stored in the same sized tank than a single stage unit. This would have the result of increasing the usage time between motor starts for any common consumption rate.
Two stage units are a little more efficient in the HP required for a similar capacity and provide cooler air at similar pressures to single stage units, mainly because of the interstage cooling that takes place. If you have to work a single stage unit hard without some kind of dedicated aftercooler, the higher air temperature will result in less effective condensation and removal of moisture, especially in hot, humid weather. This can be a problem for any compressed air use, but is especially important in blasting and painting. It can be overcome by special attention to moisture control equipment. The same problem exists in a two stage unit too - just to a lesser extent - and only because the air comes off the compressor at a cooler temperature to begin with.
In summary, two stage units are more likely designed for continuous duty, run slower, last longer, run cooler and run more efficiently regarding power consumption. They are more expensive but are typically a "better" all around unit. Are they needed for most home shop purposes? No.
third party image Rod
Frank Stalfire
03-22-2005 19:30:46
 Re: One Stage vs. Two Stage Compressors in reply to Rod (NH), 03-21-2005 20:22:33
Rod
your reply's are so detailed it's great having you here and reading your posts, I don't think this forum would be as good as it is with out guy's like you and CNKS, personally I don't know how you can type so much, I get tired after a couple of lines.
CNKS
03-23-2005 06:32:20
 Re: One Stage vs. Two Stage Compressors in reply to Frank Stalfire, 03-22-2005 19:30:46
I think Rod knows how to use all his fingers, I can use all of mine, but they keep hitting the wrong keys --
Rod (NH)
03-23-2005 09:28:00
 Re: One Stage vs. Two Stage Compressors in reply to CNKS, 03-23-2005 06:32:20
:o). Actually no, I'm a two finger type. But I can go pretty fast...as long as I can see the keyboard. My wife's computer has many of the keys so battered that the letters are no longer visable (cheap keyboard). Because of that it is next to impossible for me to use hers for anything other than a very slow, methodical hunt and peck, trying to remember where particular letters are located.
JKC
03-22-2005 03:59:40
Hi Rod. Thank you so much for such a detailed response to my question. I know very little about these compressors and feel that I know more now. Your explanation was very throrough.
Thanks again! I appreciate the time you took!
