dry paint
Ken C.
03-23-2005 16:56:37
My primer is drying almost before it gets to the metal, powder piles up and makes a mess. It is acrylic enamel, what is causing this not mixed right, or wrong thinner, any help is appreciated, Ken.
Mike S 806/H
03-24-2005 15:37:53
 Re: dry paint in reply to Ken C., 03-23-2005 16:56:37
Turn your air pressure down and open the paint valve up.
Rod (NH)
03-23-2005 20:06:28
Hi Ken,
See here.
third party image Rod
G
03-25-2005 17:06:06
 Re: dry paint in reply to Rod (NH), 03-23-2005 20:06:28
Make sure your using a good quality laquer thinner and not mineral spirits. I"d most likely say that you don"t have the primer thinned nearly enough. Try 40% primer and 60% thinner, you want it to flow out smooth. Three to four coats at least, don't try to cover in one coat.
Depending on the gun run at 40 to 60 psi.
Good Luck!
Gene
