Rust Destroyer Primer?
rfm
03-25-2005 13:26:54
I posted this about a month ago & got no responses. Thought I'd try again.
Any one out there ever use a product called Rust Destroyer? Sounds like it can be used as a primer on rusty metal. It is red in color and come in quarts, gallons & spray can.
Jim V.
03-27-2005 03:58:48
 Re: Rust Destroyer Primer? in reply to rfm, 03-25-2005 13:26:54
I've used this quite a bit. It's best to remove the heavy rust though. It will stop the rusting process and serve as a primer for the paint. I've found that it is pretty thick and I brush it on rather than trying to spray. Seems to work well. Paint sticks to it very well. Good luck.
JTR
03-26-2005 06:31:40
I have used several types of rest restorer but at the moment I do not recall the brands. I have found that it works well and plan to use it again on a skid steer.
I did remove the scale and powedry surface rust but didnot take everytrhing down to shiny bare metal. I followed the instructions on the lable. One brand said that it should not get on the painted surface and I do not know why. It will dirty the paint but if you plan to repaint what does it matter. On one project I left the metal unpainted as I liked the antique look left by the restorer.
Hope someons sends beter info.
Johnnie
CNKS
03-26-2005 09:08:38
 Re: Rust Destroyer Primer? in reply to JTR, 03-26-2005 06:31:40
It says don't get it on the paint because it has to have rust to work properly --- .
CNKS
03-25-2005 19:03:01
I didn't respond because I like to physically remove the rust, thus I don't use that type product. What you mention might be ok for an old rusty implement, but I wouldn't use it on a tractor.
