stripping paint
nobull68
03-27-2005 04:51:11
We are going to strip and repaint our tractor ,we are going to sandblast the sheet metal but i do not want to sandblast the tractor frame.do they make a liquid stripper that can be sprayed or brushed on that will take off old paint?
CNKS
03-27-2005 10:43:12
 Re: stripping paint in reply to nobull68, 03-27-2005 04:51:11
About any commercial paint stripper will work -- even that sold by Walmart. The so-called "aircraft stripper" may be better. It may take more than one application. Get one that has a thick paste, not the thin runny stuff. You still have to sand the sheet metal when you are done. I don't know that you will get much warpage with the typical homeowner sandblaster -- commercial, that's another issue. Just be careful and pay attention to what you are doing.
msb
03-27-2005 09:11:42
If I were going to sandblast anything I would choose the frame and not the sheet metal.Sandblasting can warp sheet metal.But I don't like the result of sandblasting anyway.It destroys too much metal to suit me. About any commercial paint remover will do a good job of better still use the lye gravy method.Its a mixture of lye and corn starch and is a lot cheaper the paint stripper.Paint it on and power wash the old crud and paint off.Sorry,I have misplaces the website that gives the directions for the lye gravy.
Josh-Il
03-28-2005 16:08:35
 Re: stripping paint in reply to msb, 03-27-2005 09:11:42
Have any of you ever heard of using ground cinders to blast with? Does it work?
msb
03-27-2005 09:14:10
 here it is in reply to msb, 03-27-2005 09:11:42
Link
