Hi Debbi, If you are talking about the codes obtained from a link over on the left side of this page, I would take them all with the proverbial grain of salt. Your C was originally in persian orange. There are two different persian oranges that were used by AC. The early version was a pumpkin shade of orange and you will sometimes hear it referred to as "persian #1". That early version was used up until about 1960, which means all Cs were of the early shade of the color. The later version has more red in it and is sometimes referred to as "persian #2". I have never seen a paint manufacturer refer to the two colors as #1 or #2 so you have to be careful. The earlier shade is much harder to find than the later one. Here's a visual comparison of the two in PPG codes, compared with the original paint from my '42B. All Bs and Cs used the same early paint shade. If you want to be original (or just prefer the shade), you want the PPG 60080. It is the closest match you are likely to find. The 29047 DuPont Dulux mentioned at this site is old history. Dulux was a very popular alkyd enamel used for a very long time. It went the way of the Dodo bird quite some time ago. If you went to a DuPont dealer and asked for 29047 Dulux, they probably would have a laugh at your expense. You'd be twenty years too late :o). The 29047 also has too much red in it and is much more like the later persian orange. The closest thing I have seen in DuPont to persian #1 is code YS074. If you wish to stick with DuPont, that's the one I would recommend. It's a generic color called "Spectramaster Yellow". Don't let the name fool you. It's definitely an orange. Jason (ma) has had some visual sprayout panels posted on this board with several trial codes for the early persian color, including the YS074. The links escape me at the moment. Do a search in this forum on Jason (ma) and you should find the pictures easily. It was within the last 2 or 3 of months, I think. Here's what the PPG 60080 looks like on my '42B. You can also get another good comparison of the PPG 60080 with original here. Compare the gas tank with 60080 and the faded original underside of the fender. I assume you are talking a spray application. If you decide on either PPG or DuPont, you will also have to decide on paint chemistry. Each company can mix the same color in more than one chemistry. Cost and application safety are two issues for the "backyard painter" to consider. If you need more information on these matters, postback and someone will help out. Rod
