Dented Oil Pan
PaulW_NJ
04-28-2005 20:40:10
I removed the oil pan on my IH 340U to remove the rust and old flaking paint, and was surprised to find how dented it was on the sides and bottom. Guess the rust was helping it look less apparent : will be a lot more visible once the pan is cleaned up and painted. Has anyone done "bodywork" on a oil pan to straighten out the sides? I suppose you could hammer from the outside against the end of a 4x4 placed inside . . .
pgo12
04-29-2005 02:17:00
 Re: Dented Oil Pan in reply to PaulW_NJ, 04-28-2005 20:40:10
just hammered out the one on my farmall regular. used a 2x4 on the flat parts [2x4 on the inside], and rounded a 2x4 for the inside, side edges. worked real well. got it where it was staight, then used a polishing wheel and cleaned it up. used very little filler that way, and then painted. works well. pg
PaulW_NJ
05-01-2005 18:38:10
 Re: Dented Oil Pan in reply to pgo12, 04-29-2005 02:17:00
Thanks - glad to hear it worked. I'll give it a try . . . the oil pan is so visible I'd like it to look as good as the rest of the engine.
