PPG PAINT---8N
BK --PENNA
05-07-2005 12:10:24
ANYBODY KNOW THE PPG CODES FOR THE CORRECT RED AND GRAY FOR AN 8N?
Rod (NH)
05-07-2005 18:12:36
 Re: PPG PAINT---8N in reply to BK --PENNA, 05-07-2005 12:10:24
Hi,
There are several different PPG color codes for red and gray for Ford tractors indicated here. I suggest you also try on the Ford N forum to see if you can't narrow it down between the choices. Having more than one shade for the same color over the years is not unusual in tractors. It takes a real specialist in researching the particular tractor brand to get a handle on exactly what was used when. Even then, the choice(s) may not be perfect and only a "best match possible", considering changes in paint chemistry throughout the years.
third party image Rod
BK -- PENNA
05-09-2005 03:20:48
 Re: PPG PAINT---8N in reply to Rod (NH), 05-07-2005 18:12:36
THANKS ROD. THAT HELPS ALOT.
