hardener ?
ty
05-07-2005 18:57:50
I am painting a old jd tractor with the jd synthetic enamel and I want to add hardener. I have heard that dulux 77s is good. I used marhyde wet look hardener las time and I achieved very good gloss as a result. However, With the marhyde, the paint reacted to gas spills and I heard the 77s is better for protecting against this. Is it ok to mix a little of each hardener in the paint?
dufrain
05-09-2005 19:27:22
 Re: hardener ? in reply to ty, 05-07-2005 18:57:50
I have had good luck with the marhyde ultra wet look,Its the one in the yellow can.It supposed to be their best one.Kirker super wet look is supposed to be the same thing.One step up from the wet look,maybe it will be better agianst gas,I have uused it on alot of cars and trucks and never had trouble with the paint around the fuel filler area.It makes the paint get really hard and glossy.I never have tried to mix hardners.The marhyde works good in all the implement paints I have used also.
